Error when using URL "Unsupported authentication mechanism -> 'Basic', could not be used as fallback.
kart_ramalingam
Newcomer
I get thee error in the browser
""Unsupported authentication mechanism -> 'Basic', could not be used as fallback."
when accessing
https://xxxxx.live.dynatrace.com/api/v1/problem/feed?impactLevel=INFRASTRUCTURE&relativeTime=hour/?Api-token=putyourapitokenhere
or
https://xxxxx.live.dynatrace.com/api/v1/problem/feed?impactLevel=INFRASTRUCTURE&relativeTime=hour?Api-token=putyourapitokenhere
However when I access
https://xxxxx.live.dynatrace.com/api/v1/problem/feed?Api-token=putyourapitokenhere
But this also only lists 3 events although it says has 538
4 REPLIES 4
Dant3
Pro
Hey mate, the ? is for when you stop using the apiendoint (in this case api/v1/problem/feed) and start passing variables.
So for this to work send something like this:
https://xxxxx.live.dynatrace.com/api/v1/problem/feed?impactLevel=INFRASTRUCTURE&relativeTime=hour&Api-token=putyourapitokenhere
The last variable is the token, so you pass the data as another (&) variable as you did for impactlevel and relativetime. With that the api call will work.
Services Solution Engineer @PowerCloud - Observability/CloudOps Certified / Former SE @Dynatrace.
Thanks mate. IT works like a charm.
Babar_Qayyum
Hello @Dante P.
While downloading the agent from the browser getting the following error:
{"error":{"code":401,"message":"Unsupported authentication mechanism -> 'Basic', could not be used as fallback."}}
Any thoughts about it?
Babar
Hey @Babar Q. i didn't notice this question. Sorry.
In our case this url (for our managed enviroment) works like a charm:
https://activegate_URL:9999/e/TENNANT_UID/api/v1/deployment/installer/agent/unix/default/latest?Api-Token=TOKEN&arch=x86&flavor=defaul
I think is not detecting the api_token string at the url.
