question
Yann B. avatar image
Yann B. asked ·
How to DT_CUSTOM_PROP for Tomcat
Hello based on this doc:
https://www.dynatrace.com/news/blog/define-process-group-properties-via-environment-variables-kubernetes-annotations/
I cannot understand how/where to insert the DT_CUSTOM_PROP on Tomcat runninx on linux System.
Do someone have already done this? Can you guide me to do so?
Thank you
Dynatrace Managedprocess groupsauto-detection
1 Answer
Julius L. avatar image
Julius L. answered ·
If this is a standard tomcat and you are starting it with the catalina.sh startup script, just put it in the $CATALINA_HOME/bin/setenv.sh script (or create it).
Don't forget to export the variables, for example:
export DT_CLUSTER_ID=tomket1
export DT_NODE_ID=mynode1
export DT_CUSTOM_PROP=myprop=myvalue
1 comment Share
Thank you this was the right solution for me, 9 points to gryffindor!
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
