Is there a way to get execution plans for MSSQL in Dynatrace Cloud?
soconnell
Newcomer
Currently I am trying to find out if there is a way for me to pull the execution plan of a query down or visualize it in the Dynatrace hosted solution. Is there a plugin for Activegate (i didn't see one but totally could have missed it)?
7 REPLIES 7
Mike_L
Dynatrace Guru
Dynatrace Guru
There is currently no such functionality for MSSQL. For Oracle that is something that is part of the database insights. A similar database insight product is also planned for MSSQL
Mike
Mike
Thanks Mike! you happen to be privy to any kind of eta at all on that?
Probably next year.
Mike
Roman_F
Frequent Guest
Is there any update on this?
Not yet, with extension framework 2.0 the roadmap shifted somewhat. @dglugla has the new database extensions on his radar.
Mike
Bill_Demsky
Helper
Please consider logging the SQL statements even without query plans. This would allow us to get the problem statement based on duration, capturing the bind variables would be a plus to we can see the parameters of the statement.
Tom_Eaton
Dynatrace Advisor
Dynatrace Advisor
