• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Vaclav S. · Nov 21, 2019 at 12:02 PM · alerting business transaction 7.2 measures sensors
Using CPU measure in Business transaction filtering
Dear community, I was not able to find a solution for this?
When defining a BT filter only transaction based measures are offered to use.
Is there some way how to do iT?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Sebastian K. · Nov 22, 2019 at 07:52 AM
Business transactions by it's definition are transaction / visits based entities. What is your case in general. What do you want to do :)
Comment
0 Show 1 · Share
avatar image Vaclav S. · Nov 22, 2019 at 08:16 AM 0
Share
I would like to filter particular measure threshold trigger - so the threshold would be active only when CPU load is lower than let us say 15 percent. Cause when there is higher load the response times go high too and it triggers false alarms.
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
29 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Is possible to custom email notification ?
Is it possible to make a rule that verifies the swap growth in a time period?
Visits with No Errors
Measure for the time taken in one method filtered by some parameter
Is there a way to globally exclude clients
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
