DT_CUSTOM_PROP and spaces
florian_zimmerm
Newcomer
is there a (as of yet) undocumented way to get in values with spaces (key/value) metadata (or tags by using DT_TAGS). is there a way to escape spaces or using a special character interpreted as space in dynatrace?
we have the need to set a key 'support_group', and it needs to hold values like 'department web - team1, department web - team2, ...'.
https://www.dynatrace.com/support/help/how-to-use-dynatrace/tags-and-metadata/basic-concepts/best-pr...
thanks in advance, florian
7 REPLIES 7
skrystosik
As I know it isn't supported right now.
Regards, Sebastian
sean_mcconville
Organizer
Did this ever get addressed?
alex_luchs
Visitor
Yes, this would be really great to be supported either through quoting the value (key="value with spaces") or escaping with backslashes (key=value\ with\ spaces). Other tagging techanisms, including manual, AWS tag ingest, etc. allow for spaces. Why not DT_TAGS environment based tags?
Hello @florian_zimmerm  and @alex_luchs
As we know spaces are used to separate tag values until now. Therefore, please go ahead and open an idea to enhance the application's capability.
Babar
Sorry for not seeing your reply for a month. Whoops!
I've created the product idea here: https://community.dynatrace.com/t5/Dynatrace-product-ideas/Add-support-for-spaces-in-tag-values-prov...
Hi all,
We are facing a similar issue on our side with DT_CUSTOM_PROP
A couple of days ago, we have noticed a Dynatrace bug with DT_CUSTOM_PROP which translate "tabs" into "spaces"
We are benefiting from this bug as we are now using tabs whenever we need spaces... and as a workaround, this works for us including for auto-tagging !
In your example above, this would be
export DT_TAGS="value	with	spaces"
where there is a tab between value and with and another tab between with and spaces
This is seen better in below screenshot using vi with :set list
Tabs are represented as   ^I   special characters
Maybe this workaround will help while Dynatrace is considering the product idea to support spaces officially.
Hope this helps,
Kind regards,
David
prasad_arugonda
Participant
Instead of space, you could use a tab (is a tabulation character). this worked for me
