How do not register a problem when the client machine with the agent will turns off
MAkimov
Mentor
Hello
We have several user computers with software installed that we need to monitor.
We installed OneAgent there. All is good.
but the problem is that when users go home in the evening or on the weekend they turn off their computer.
Dynatrace detects a problem that the host is Host or monitoring unavailable
Is there any way to configure it so that turning off the computer does not register a problem?
maybe can I set time intervals when not registering a problem for Host or monitoring unavailable (only this problems) ?
7 REPLIES 7
HannahM
Dynatrace Leader
Dynatrace Leader
If the users have standard working hours you could apply maintenance windows to now create problems during those hours. There is documentation on this here
Best wishes, Hannah
Hello @Hannah M.
Thank you for the information, but I am aware of the possibilities of the maintenance windows.
Firstly, users can leave at different times.
In the second, I would like to exclude only the registration of an alert about Host or monitoring unavailable (only this problems). In the maintenance windows I do not see such an opportunity
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
No please do not use a maintenance window for that purpose. You can simply switch it off for those workstations, as shown below:
Hello @Wolfgang B.
I need that problem will be not register (or it will be like an information event)
First result
Settings:
Problem is registred
Second result
Settings:
dave_mauney
Dynatrace Champion
Dynatrace Champion
On the Host/Anomaly detection page, toggle "Detect host or monitoring connection lost problems" off.
yes, that’s understandable.
but then if there is a real problem during working hours with host unavailability, I may not know about it
I would like to be able to turn off only the alert for "Detect host or monitoring connection lost problems" within the settings of Maintenance window
dave_mauney
Dynatrace Champion
Dynatrace Champion
Maybe you could use a scheduled cron job (or similar) to modify the Management Zone used for the alerts to add or remove scope as needed?
