Problem Auto-Remediation With DynaTrace
richard_newboun
Newcomer
Hi all,
We're looking at the next phase of our DynaTrace deployment and how we can automatically act on certain problems (automatically execute scripts, restart services, etc.). Can anyone advise which tools have been used and integrated into DynaTrace to perform the orchestration of these remediation tasks. I have no preference, so any recommendation would be gratefully received!
Richard
6 REPLIES 6
JamesKitson
Dynatrace Guru
Dynatrace Guru
ChadTurner
DynaMight Legend
DynaMight Legend
James is Exactly right, Ansible tower can be used for auto remediation as well as deployments and can be very useful. I would recommend looking into leveraging the product.
-Chad
kvsudheerbabu
Observer
Do we have a similar one for Terraform in AWS?
Hi @kvsudheerbabu,
Could you please check these links:
Docs overview | dynatrace-oss/dynatrace | Terraform | Terraform Registry
GitHub - dynatrace-oss/terraform-provider-dynatrace
I hope it helps.
Best regards,
Mizső
Thanks for your quick response.
How can we use these terraform modules to restart a specific process or host that were reported as part of metric event problem?
Sudheer
Hi @kvsudheerbabu,
I have shared those links becasue you can find inofrmation about the DT and Terrafrom integration. I have never used Terrafroam.
As in the previous answers in most cases I have met with Ansible Tower job template solution for autoremediation.
This is an Azure example:
Best regards,
Mizső
