after making the infection in a few pages, I get this error.
Could help me solve a this problem?
An error was detected on the page:
http://xxxxxxxxxxxxxxx/Site/dynaTraceMonitor?bwstate=0&unique=1396012155084
Description of Error:
The controller for path '/Site/dynaTraceMonitor' was not found or does not implement IController.
System.Web.HttpException
Refer : https://xxxxxxxxxxxxxxxxxxx/Site/ListaGerenciadaVisualizarListaSugestiva.aspx?idListaCompra=346158&sugestao=10188&xxxxxxxxxx=0&paginaAtual=24&numPorPagina=10
UserAgent : Mozilla/5.0 (Windows NT 6.1; Trident/7.0; rv:11.0) like Gecko
.Net Erro Stack |
The controller for path '/Site/dynaTraceMonitor' was not found or does not implement IController.-- at System.Web.Mvc.DefaultControllerFactory.GetControllerInstance(RequestContext requestContext, Type controllerType) at System.Web.Mvc.DefaultControllerFactory.CreateController(RequestContext requestContext, String controllerName) at System.Web.Mvc.MvcHandler.ProcessRequestInit(HttpContextBase httpContext, IController& controller, IControllerFactory& factory) at System.Web.Mvc.MvcHandler.BeginProcessRequest(HttpContextBase httpContext, AsyncCallback callback, Object state) at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) |
Answer by Christian S. ·
hi Alfredo,
I just talked to one of the developers and the root cause of your issue may already be known.
so it would be best to open a support ticket to get adequate help.
best, Christian
hi Alfredo,
so you have an IIS agent who is responsible for UEM injection as far as I understand, right?
do you have some PurePaths, where this occurs which you could attach here?
best, Christian
hi Alfredo,
how did you configure UEM?
especially: how do you inject the javascript agent?
because it seems like the dynaTrace monitor signal is sent to a .NET agent, which is an unsupported setup.
best, Christian
hi Chistian,
these settings are IIS
and these are .Net
UEM Settings:
Is there some wrong setting?
Thanks!
