• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Dale S. · Mar 28, 2012 at 09:23 PM ·
Custom Setting for any Method greater than 30sec
How does one go about setting up a monitor for any method that takes longer than 30 secs. Using the dev team edition.
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Mar 29, 2012 at 02:32 PM
Hi Dale
The Methods Dashlet has no filter that allows you filter on Exec Time >= 300ms. What you can do though is to create a dashboard with the Method Dashlet on it. Switch it to "Method only View" (through the toolbar on the top right) and then sort by Exec Time.
Now you can use the Server-Side Reporting Interfaces and query that dashboard using REST. You will get an XML Document that represents all of the data on that dashlet. With some coding or even with an XSLT Transformation you should be able to only look at those methods exceeding the 300ms threshold.
One thing to remember here: The Methods Dashlet doesnt show each individual method invocation but aggregates by Method. So - if one method was executed 10 times the total sum might be > 300ms - but every individual execution might be < 300ms.
If you want to look at each individual method invocation there is another option you can:
Open the PurePath Dashlet to look at those PurePaths you are interested in. Select All of them and then switch to the Contributors Tab. Now sort by Exec Total and focus on those methods that have a Total Exec Time of > 300ms. Advantage of this method is that you immediately see the PurePath for it.
Let me know if this helps and if this is what you want
Andi
Comment
0 Show 0 · Share
avatar image
Answer by Dale S. · Mar 29, 2012 at 01:34 AM
If I am looking at methods and sorting by Exec Sum [ms], and I want to only see the the ones that are over 300ms in a Report, how do I do this.
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
3 People are following this question.
avatar image avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
