• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Matt J. · May 10, 2012 at 05:15 AM ·
Chart dashlets work fine in staging, but not in prod
I have a dashboard that consists of 6 chart dashlets. It works great on our staging server, but I'm only seeing the "no measurements available" message on the same dashboard in production. We copied sensors and measures over from staging to prod, and for the dashboard, I just did a 'save as'. I made sure to update the data source and agent filter accordingly.
Adjusting the timeframe doesn't seem to make a difference; I get "no measurements available" whether the timeframe is 30m or 30d. We bounced our production app containers 2 days ago because we initially thought that was the problem, but apparently it wasn't.
Comment
Himanshu M.
People who like this
1 Show 0
â–¼
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Matt J. · May 12, 2012 at 04:20 AM
In that case, yes, the OOB measures are charting correctly. I guess we'll file a support ticket and find out what's going on.
Comment
Himanshu M.
1 Show 1 · Share
â–¼
avatar image Andreas G. &. · May 13, 2012 at 01:35 PM 1
Share
please do so and keep us posted on the outcome
avatar image
Answer by Matt J. · May 11, 2012 at 12:53 AM
Everything else appears to be working OK. Is there any way that this could be a permissions problem?
Comment
Himanshu M.
1 Show 1 · Share
â–¼
avatar image Andreas G. &. · May 11, 2012 at 04:23 PM 1
Share
With my question on "do you get other measures" I wanted you to create a new Chart and add some of the "out of the box measures" to the chart to verify if these are there.
If this problem persists - please open a support ticket. When doing so you will send in your Support Archive that contains your client, server, ... log files. This will help our support engineers to pinpoint the problem
Cheers
avatar image
Answer by Matt J. · May 10, 2012 at 08:20 AM
The measures look OK to me. I deleted both of them and re-added, but the result is the same.
Comment
Himanshu M.
1 Show 1 · Share
â–¼
avatar image Andreas G. &. · May 10, 2012 at 05:28 PM 1
Share
Is your Performance Warehouse connected correctly? Do you get any other measures from this System Profile such as PurePath Duration, DB Count, ...?
If you cant resolve that problem I suggest to contact our support team - they can have a closer look at your installation
Andi
avatar image
Answer by Andreas G. · May 10, 2012 at 08:13 AM
Two additional things to check
a) toggle your chart into table view and see whether the measures you put on that chart have a red X in front of it. this would mean they cant be found on the current data source
b) try to add one of these measures again using the "Add Series" option. If these work double check if there might be a difference in measure names
andi
Comment
Himanshu M.
1 Show 0 · Share
â–¼
avatar image
Answer by Matt J. · May 10, 2012 at 08:10 AM
Nope, no dashlet-specific data source configured for any of the dashlets. They should all be getting their data from the dashboard data source location, which is production.
Comment
Himanshu M.
1 Show 0 · Share
â–¼
avatar image
Answer by Andreas G. · May 10, 2012 at 08:05 AM
Make sure you dont have Dashlet specific filter. It often happens that you put charts on a dashboard that then have a dashlet specific data source. Right click on the header of your dashlet -> Dashlet Properties -> and check your source settings
Comment
Himanshu M.
1 Show 0 · Share
â–¼
Join the conversation!
First steps in the forum
Community User Guide
LIVE WEBINAR
"Power Demo: Software Intelligence for Cloud Infrastructure"
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Register here
Live webinar: Ensuring Digital Business Availability with Dynatrace
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api errors dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java browser agent community user guide hybris javascript appmon sensors good to know search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow diagnostics user session monitoring unique users continuous delivery configuration alerting NGINX splitting business transaction client 6.3 installation chart database scheduler apache mobileapp RUM php dashlet azure purepath plugins agent 7.1 appmonsaas messagebroker nodejs 6.2 incidents android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
