Hi, can anybody help me.
I just downloaded dynatrace-4.1.0.2974-x64.msi to install on my brand new 64bit - Win7 system.
When I run te installer everything seems ok.
The Collector is up and running, the server is up and running.
But in mij start menu or Program Files folder I can't find the Dynatrace Client.
As if it wan't installed.
Answer by Roman S. ·
You are correct, it was not installed. Since we do not have a 64bit version of the client it is not part of the full install package for 64bit. Two options - you can download the 32bit client installer (seperate link) or you can use the Webstart client provided by the server (e.g. http://localhost:8020/webstart/Client/client.jnlp).
Best, Roman
