• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Pankaj K. · Aug 22, 2012 at 09:56 AM ·
Transaction Flow Dashlet Values
I am creating a dashboard that I would like to schedule as a weekly report to management. I am trying to figure out a way to display the following data that appears in the top of the Transaction Flow dashlet.
- Total Transactions (count) (per minute count)
- Failed Transactions (count) (% that failed)
How can I get these values into my custom dashboard?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Aug 27, 2012 at 02:33 PM
Hi
For Total Transactions you can chart e.g.: "PurePath Duration" and then change the aggregation to "Count" (right click on the Measure in the Chart Table).
For Failed Transations simly take the Failed Transaction Percentage measure
hope this helps
Comment
0 Show 3 · Share
avatar image Pankaj K. · Aug 31, 2012 at 08:49 PM 0
Share
Andreas,
Thank you. I was able to get the transaction count using Purepath Duration.
However, for failed transactions, the Failed Transaction Measure won't work because this email is a "weekly" report. In my installation the failed transaction percentage measure only seems to contain data for the past hour. Is there a way to get it historically?
Also, I am able to get the Unhandled Exceptions Count aggregation. Is there a way to create a measure that divides two other measure values?
avatar image Andreas G. ♦ Pankaj K. · Sep 03, 2012 at 02:49 PM 0
Share
Hi
The Failed Transaction Count is available for more than just the last hour. What you need to do is to put it on a chart that shows a longer timeframe, e.g: 7 days.
As for your second question. There is a "Rate" measure that calculates the rate between two measures:
Hope this helps
avatar image Pankaj K. Andreas G. ♦ · Sep 05, 2012 at 10:51 AM 0
Share
That solves it. Thanks!
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
