question
Sreerag M. avatar image
Sreerag M. asked ·
Define applications for purepaths starting at custom entry points?
We have sensor configuration defined to start purepaths on specific methods. However all of these purepaths are having 'Default Application' as its application name. We have application definitions but somehow these custom entry purepaths are not mapped to those applications. Pleas advice on how to map these purepaths to our custom applications.
Sreerag
1 Answer
Rob V. avatar image
Rob V. answered ·
Hi Sreerag,
Currently, application mapping is based on URLs only and can't be set up to reflect a specific method, EJB, etc.
There is a "request for enhancement" already to extend this functionality. Please visit this link and "vote" for it, and add  your own comments as well:  https://apmcommunity.compuware.com/community/pages/viewpage.action?pageId=102826013
This will help product management prioritize new features and requests.
Rob
3 comments Share
Thanks Rob.
Looks like for now the application name will be 'Default Application' and that is ok; however we don't see the Default application in the 'Application Overview'  for some of our profiles. Is there a way to get the 'Default Application into the the overview page?
- Sreerag
0 Likes 0 · ·
Hi Sreerag,
The 'Default Application' will only show up in the App Overview if there are requests coming in. Note that the app overview is based on business transactions - so depending on what BTs you have select you might have requests coming in but because they are not part of the BTs it shows no load. CLick the little cogwheel next to the app overview on top to select which BTs should be considered for the overview dashboards.
Best, Roman
0 Likes 0 · ·
Thanks Roman, It worked.
Now I see the 'Default Application' in the App Overview.
- Sreerag
0 Likes 0 · ·
