Hi Team,
In Transaction Flow diagram ,it shows RED in agent or Tier when there is failed transaction.
I want to know criteria for failed transaction or which error are reflected in transaction flow.
Can we customize Error criteria?
Jalpesh
Answer by Andreas G. ·
The error color should reflect the errors detected with our Error Detection Feature. So - in your case it looks like a bug. I see that your transaction flow uses a Business Transaction Filter. Maybe thats the special issue here.
Can you post this in a support ticket?
Hi Andy,
In my case ,in Java Script Agent there is no transaction failed still it showing RED .
I am raising support case for this.
regards,
Jalpesh
Answer by Jalpesh S. ·
In my case it shows "Failed transaction 0" but when I clicked on Show Errors in error Dashboard it shows important logging error.
So I want to know which Error Rule is used for Transaction flow??
Jalpesh
