hi
dynatrace version 4.2 appserver was 7.0 nd ,
jvm :
java version "1.6.0"
Java(TM) SE Runtime Environment (build pwa6460sr12-20121025_01(SR12))
IBM J9 VM (build 2.4, JRE 1.6.0 IBM J9 2.4 Windows Server 2008 R2 amd64-64 jvmwa
6460sr12-20121024_126067 (JIT enabled, AOT enabled)
J9VM - 20121024_126067
JIT - r9_20120914_26057
GC - 20120928_AA)
JCL - 20121014_01
thanks!
huamin
Answer by Roman S. ·
HSP is not turned on by default on IBM JVMs, we had some problems with stability in the past thus the default off. If you want to enable it go to the advanced agent settings in the system profile - agent group - agent mapping tab and change it to "Always On".
Best, Roman
