• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by Anton G. · Aug 15, 2013 at 09:24 PM · agent collector
How does the Byte code instrumentation work?
I am note sure that I am venturing into trade secret area here.  If I am, let me know....
A bank have bought 17 JAVA agents.  There was a huge debate about Collectors.  In essence, they want to know how the agent and collector interact.
If we say that "dynaTrace Collector is responsible for the instrumentation of the dynaTrace Agent" does that imply we send the java code in plain text to the collector, where it is instrumented and then back to the agent?  As this might be a security risk if these are sent around on their network.  If the collector is on the other side of a firewall (yes I know but they are trying to save on collector machines as they have 84 DMZ's) would this expose their code?
Also, should the firewall be opened bidirectionally or only from agent to collector and collector to server?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Christian S. · Aug 16, 2013 at 11:51 AM
hi Anton
yes, the Java classes are sent as they are (i.e. the Java bytecode, NOT source code) to the Collector and back. if they don't want the classes to leave the machine/network, they'd have to put collectors on those machines/in those networks.
opening the firewall only from agent -> collector -> server should be enough, as the TCP connections are always established in this direction.
hope this helps,
Christian
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Related Questions
problems restarting 6.2 host agents services on windows servers"severe [native] Exception in controller: receiveExact() ... not connected, 730053, Software caused connection abort. Retrying every 10 seconds.
appmon and classic agent change - affects agents connectivity (not sure whether agent group changed)
Agents ambiguously mapped and disconnected
Instrumentation Disabled because not all Transformation were completed successfully
Is it possible to connect a NodeJS agent to a collector group where collectors do not necessarily listen on the same port?
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
