• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by wim d. · Aug 20, 2013 at 11:54 AM ·
Dashboard migration problem
I have developed a new dashboard in my dynaTrace Test Center Edition. Now I want to move this dashboard to PROD; I used to do this by saving the dashboard from the Test Center Edition to my local machine, then logon to PROD and open the dashboard there. After some minor modification (data source!) the dashboard can then be saved on the dT server.
It seems this process does not work when the target dT-version is lower than the source version (Test is 5.5, PROD is 5.0).
Is there any way around this?
Wim.
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Jaydatt D. · Aug 22, 2013 at 01:30 PM
Hi Wim,
Just open you dashboard xml file in notepad and check whether xml file which you are trying to import is complete or not.
Also delete if white space is present at the end of the code and then try to import the xml.
Best Regards,
Jaydatt.
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Aug 20, 2013 at 12:15 PM
The problem most likely is that your 5.5 dashboard uses dashlets that are not available in 5.0? Is there any error message that you get?
Comment
0 Show 4 · Share
avatar image wim d. · Aug 20, 2013 at 01:23 PM 0
Share
The only messages I get are:
I can build the dashboard from scratch in 5.0; it has the same look & functionality as the 5.5 version, I am not aware of using 5.5-only dashlets.
Wim.
avatar image Andreas G. ♦ wim d. · Aug 20, 2013 at 01:35 PM 0
Share
Can you go to the System Information Dashlet and open the client log file? There might be a more detailed error message in that log file
avatar image wim d. Andreas G. ♦ · Aug 20, 2013 at 03:23 PM 0
Share
The log says:
2013-08-19 11:23:03 SEVERE [com.dynatrace.diagnostics.client.communication.AbstractCommunicationManager$11] communication error 'Requesting dashboard configuration':: com.dynatrace.diagnostics.client.communication.AsyncCallJob jobFinishedWithErrors:136
Meanwhile I noticed that there are some differences in the Business Transaction definitions that are used by this dashboard (in test there is an extra measure). Can that explain the problem?
Wim.
avatar image Andreas G. ♦ wim d. · Aug 20, 2013 at 03:25 PM 0
Share
That most likely is the problem. You can also have a look at the server log files and search for an error
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
