• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by amol k. · Nov 02, 2013 at 10:31 AM ·
Unable to get module info for expression
I'm getting below exception in logs for DotNet agent
 info [native] Unable to get module info for expression_host_b00fa49823a048e68b75a01fe7cbeac3.dll. This is expected behavior on dynamic assemblies.
 info [native] Profiler::ModuleLoadStarted(): Cannot process assembly expression_host_b00fa49823a048e68b75a01fe7cbeac3.dll. This is expected behavior on dynamic assemblies.
As I'm not PP for this agent.
Please suggest.
Amol
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Christian S. · Nov 04, 2013 at 05:36 PM
hi Amol,
those INFO log messages do not indicate an error, just the fact that dynaTrace is currently not able to instrument dynamically in-memory-built assemblies, because there is no assembly on disk to be instrumented.
the WARNING log messages in the server log, however, should be investigated. so as Andi said, a support ticket with the server and agent logs would be best.
best, Christian
Comment
0 Show 0 · Share
avatar image
Answer by amol k. · Nov 04, 2013 at 09:58 AM
Thanks.
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Nov 04, 2013 at 09:16 AM
So that means you get PurePaths in the beginning and then they stop? If that is the case I suggest you open a support ticket so that our engineers can have a look at it
Comment
0 Show 0 · Share
avatar image
Answer by amol k. · Nov 04, 2013 at 08:53 AM
Hi Andi,
Thanks for info, but I'm getting this issue after some time of application restart.After application restart it works fine for 5-10 minutes then its starts giving me error in logs
agentlogs.txt
Please suggest.
Amol
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Nov 02, 2013 at 11:59 AM
The second message indicates that you have an agent that is not known by the server. check your agents overview and dashlet and check if the agent is listed and if everything is "green". Try restarting that application and try again.
The "info" message you posted in the beginning is probably not related with you not seeing purepaths - it is the second message that indicates that all events from that agent are simply ignored because the server "doesnt know" this agent
Comment
0 Show 0 · Share
avatar image
Answer by amol k. · Nov 02, 2013 at 10:52 AM
I have also observed below messages in Server logs
"Received events for agent (agentId: 7db5b561) that is not registered on server. Skipping events. Suppressing this warning for another 60000 ms."
Please suggest.
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
