• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by Sreerag M. · Feb 01, 2014 at 06:12 AM ·
'HTTP URL Connection Tagging' sensor not found
We are not finding the 'HTTP URL Connection Tagging' sensor in dynatrace version above 4.1. Was this removed in latest versions or replaced with another sensor.
Either way, most of our purepaths are now broken into two where as in earlier version of dynatrace these used to be single purepaths.
Can we know what has changed on this sensor?
Also how do we troubleshoot the purepaths disconnect issue.
-Sreerag
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Rob V. · Feb 02, 2014 at 09:46 PM
Sreerag, what are the classes of the bracketing classes on both sides of the call? In particular any HTTPClient calls. I've seen the PP break if there was some less-popular or perhaps custom coded wrapper on the calling side.
Rob
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Feb 01, 2014 at 09:32 AM
This Sensor was replaced with the JAva Web Request and .NET Web Request Sensor. Make sure that these Sensor Packs are placed and you should be all good again
Comment
0 Show 3 · Share
avatar image Sreerag M. · Feb 01, 2014 at 09:21 PM 0
Share
Hi Andi,
Ours is a Java application all the way to the back end, And we have the 'Java Web Requests' sensor placed.
This is how it is coming in the purepath. When a call is made to the backend java web service a 'getInputStream' node comes in the purepath. but the purepath call tree remains in the same agent group. And all the processing happening in the backend because of this call is in another purepath.
We could look for custom tagging, but it was working ok till we upgraded, custom taging means code change and not code change is one of the biggest advantages of dynatrace. we would like to keep it that way.
-Sreerag
avatar image Andreas G. ♦ Sreerag M. · Feb 02, 2014 at 01:06 PM 0
Share
What about the "backend" agent? Is it still instrumented? Do you see any PurePaths that make it to that backend agent?
avatar image Sreerag M. Andreas G. ♦ · Feb 02, 2014 at 06:59 PM 0
Share
yes the backend service is also instrumented, but those information are coming in different purepath. (a purepath starting at the backend).
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
