Hi!
I've been struggling with charting some business transactions.
First I create a measure - Web Request Response time, with upper threshold 1000 ms.
Then I create a business transaction that filters this measure (I use default aggregation: Aggregate last). It works very well
So I try to create a chart with this business transaction, this should be very simple to do, and I would expect to see the same in the chart as I saw when I run the business transaction itself. But whatever I try, I get "No measurements available for selected timeframe". The timeframe is the same as for the business transaction.
What can I be doing wrong?
Answer by Ingunn V. ·
Here is the definition of the business transaction:
Here is the definition of the measure:
Here is what the buiness transaction shows:
Can you try the following steps
1) Create a NEW Dashboard
2) Add a new chart
3) Add your Business Transaction Response Time Measure on it
Why do I propose this? Because many times you add a chart to a dashboard that already has a filter on it by e.g: opening a new dashboard by double clicking on a Business Transaction. In that case the chart wouldnt show data because of the dashboard filter. So - please give this a try because your BT shoudl work based on the screenshots you posted
Answer by Josh L. ·
Hi Ingunn,
Also with business transactions it's possible that it is not configured to actually store measurements in the performance warehouse. Please ensure the 'Store results in Performance Warehouse' is checked in the BT configuration box.
If it is indeed enabled, as rick said some screenshots of the configuration would be helpful.
Thanks!
Josh
