Today we are in the process of migrating DT from 4.2 to 5.6 and when connecting to the performance warehouse from DT 5.6 client, it throws a message box (big RED cross) but no message in it. We verified DB, instance and SQL login credentials and everything looking good. We are suspecting jdbc connection string generated.
I need help to resolve this issue, did anyone faced this issue with 5.6 migration earlier.
SQL Database SQLSERVER 2012
Host Name: SERVER_NAME\INSTANCE_NAME
Database Name: dynaTraceTCE
Also passing in SQL user credentials.
Any help at the earliest greatly appreciated.
Ram
Answer by Andreas G. ·
I am referring to the dynaTrace Server Log file. You can access it through the System Information Dashlet in your Client. The dT server writes a log file and should contain information in case there is something wrong with the connectivity to the performance warehouse
