• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Venkata T. · Mar 24, 2014 at 10:32 PM ·
Conversion
My understanding is that we can get conversion if we have UEM on. But if i want to calculate conversion without UEM. Can i do that using BT or some other way?
I should be able to specify a formula to calculate conversion..something like  (Number of Orders/Vistis)*100.  is this possible? if not any other alternative?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Venkata T. · Jan 23, 2015 at 03:32 PM
This how the actual graph looks like...
Comment
0 Show 7 · Share
avatar image Kyle K. · Jan 24, 2015 at 03:42 AM 0
Share
I'm curious about this what is your time aggregation set at right now?
avatar image Venkata T. Kyle K. · Jan 24, 2015 at 04:21 AM 0
Share
i did not change the default value. i was looking at half hour interval so it should have been 1 min. I just checked for 6 hours and changed the aggregation to 1 min and i see similar behavior. Which is not right...
avatar image Rick B. Venkata T. · Jan 24, 2015 at 04:33 AM 0
Share
Hi Venkata,
The method for this is a bit simpler than what you're attempting here...
Create a new Business Transaction and add "Count - datacache" as a Filter.  After this is created you will be able to chart the failure rate right from the Business Transaction.  Can you try this and see if it accomplishes what you want?
Rick B
avatar image Kyle K. Rick B. · Jan 24, 2015 at 04:55 AM 0
Share
Hey Rick,
Do you know why the conversion doesn't seem to be averaging out right. I'm curious about this for a different function but the Rate measure is behaving the same way for me.
avatar image Venkata T. Kyle K. · Jan 25, 2015 at 01:55 AM 0
Share
Rick,
This datacache is not an entry point, so if i use that as a filter, do you think it would give the parent purepath error rate? Also this comes as internal 404 so the parent purepath doesn't even fail due to this.
avatar image Rick B. Venkata T. · Jan 25, 2015 at 12:44 PM 0
Share
To your first question: yes, BTs evaluate per-PurePath so if it fails at some other point it will still count an error in your chart.
To your second point: internal 4xx/5xx can and sometimes should be re-classified to fail the transaction, depending on the application.  I will leave that distinction to you but you can edit the "Impact" of the internal HTTP Error rule in the System Profile -> Error Detection Dialog.
The problem with what you're attempting and why it won't calculate correctly is that the HTTP Response Code metric is supposed to be a part of a BT, and won't calculate correctly if it's not.  One thing you could do is create a BT that splits on a similar measure to "datacache - errors" but with nothing in the "Match" field.  Then you will have a count of transactions with 200, 403, 404, 500, etc.  If you wanted to represent these in percentages you can use the Stacked Percentage Bar Chart or the Pie Chart.  This would also empower you to drill down right from the error code to the PurePaths where they were detected.
Hope that helps,
Rick B
avatar image Venkata T. Rick B. · Jan 25, 2015 at 01:38 PM 0
Share
Thanks Rick for the detailed explanation. I am already doing this where i created a BT with datacache Uris and with required status. So I have one with datacache errors and one with datacache 200s. And I am charting that. But we would like to do this for each and every internal uri. Andi is looking into this ( he is going to talk to someone) and find out what is feasible.
Apart from BT approach, I am thinking why his rate feature is not working properly.  What I did is correct or not from the above screenshots?
avatar image
Answer by Venkata T. · Jan 23, 2015 at 03:30 PM
Screenshot1
Screenshot2
Screenshot3
Comment
0 Show 0 · Share
avatar image
Answer by Venkata T. · Jan 23, 2015 at 03:24 PM
Andi - since we have this available now, i tried it for calculating error percent for a particular request.  But i don't think i am getting the right values. Can you let me know what am i doing wrong here?
I selected the count of total requests as base measure and Fraction measure as errors. You can see the chart, either it is 100% or 0%. Also for the rate measure is it must that we need to enable the Percentile calculation?
i have attached the screenshots
Comment
0 Show 0 · Share
avatar image
Answer by Venkata T. · Jun 11, 2014 at 02:09 PM
Awesome. Thanks Andi for the update.
Comment
0 Show 0 · Share
avatar image
Answer by Venkata T. · Jun 11, 2014 at 02:02 PM
Andi,
You have mentioned that this feature will be available in 6. is it still on for version 6?
Comment
0 Show 1 · Share
avatar image Andreas G. ♦ · Jun 11, 2014 at 02:07 PM 0
Share
Yes - it made it into 6.0 - also see DONE: RFE - Allow use of BT result measures as input to Rate Calculation measures (Spring 2014)
avatar image
Answer by Andreas G. · Mar 25, 2014 at 07:23 AM
Hi. There is a "Rate Measure" which allows you to calculate the rate between two measures. Right now (up until 5.6) it is not possible to use a BT Result measure as input for the Rate Measures - this however changes with 6.0 which will allow this.
But - check the Rate Measure and see if that already helps you in your case.
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
3 People are following this question.
avatar image avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
