• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Tamás V. · Jun 17, 2014 at 10:40 PM ·
Web Transaction monitor - ssl certificate problem
Hi guys,
I have a problem with Web transaction monitors: I've set one up for my site (https://mysite.huhttps://mysite.hu)
I'm trying to run the monitor on a collector called "monitor" on "dynahost1". I imported the ssl certificate using keytool on "dynahost1", but after restarting the collector i still get the "sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target" error.
I checked if the cert was imported with keytool -list (in %DynaTrace_Install_Path%/jre/bin and in %DynaTrace_Install_Path%/jre/lib/security/cacerts as well) and the certificate i need is there...
Can anyone help me out? I saw a problem article (KB-418 Unable to find valid certification path to requested target ) about URL monitors, but it's not the same (i have a URL monitor which is working, tho i use that with disables certification validation)
Tamas
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Jun 18, 2014 at 03:50 PM
I am not an expert on SSL and keystore - but - when you imported the certificate make sure it is also available to the windows user that runs your collector
Comment
0 Show 1 · Share
avatar image Tamás V. · Jun 24, 2014 at 08:03 PM 0
Share
Hi Andreas,
I checked it, and it is available. I contacted support for guidance though.
Tamas
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
