• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Eric B. · Jun 26, 2014 at 03:07 AM ·
low collector memory
I had a spike in my collector memory utilization - causing the collector to disable the instrumentation on 18 of our agents.  This is the only spike I see of this magnitude.  How can I find out what caused the spike?  It occurred at 15:07 on 6-24-14
collectorLog.supportarchive.zip
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Sreerag M. · Jun 27, 2014 at 04:14 PM
I would look at the bytes received measure of the collector to see if this was caused by agents sending more data than normal.
Usually agents send more data if there is spike in request count that results in more purepaths, also if there are errors then purepaths may be long and there can be many string data in exception messages, stack trace, logs etc.
Comment
0 Show 1 · Share
avatar image Eric B. · Jun 28, 2014 at 01:54 AM 0
Share
Thanks for the suggestions!
There is no corresponding spike in bytes received, number of purepaths, purepaths analyzed or purepath length.  Those measures all fall in line with our daily business cycle.
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
