I've been looking for a way to import and set baseline data into a dynatrace pure paths to account for the aspects of our mobile transactions that cannot be captured via a installed dynatrace agent. This is primarily to support white box and black box testing of a Saas based API platform.
Here are the data sources we'd like to understand how we can tie into dynatrace purepaths.
-1 incomplete 2 complete White Box datapoints 3 incomplete Data provided by Apigee Ops (Apigee Infrastructure) 4 incomplete Test Case Data provided by LLBean Backend (dynatrace, gomez) 5 incompleteCumulative Diagnostic Metrics (CDM) - XML (Excel) based metrics collected from Apigee Management API
6 incomplete Debugging Session Data - 10 Minute snapshots of live application data that contains precise information about the API transaction. (FMI see: http://apigee.com/docs/api-services/content/get-debug-session-data ) example: trace-1406049600834.json 7 complete Black Box 8 incomplete JMeter (standard visualizations total response time (latency)) 9 incomplete Response time Apigee Layer (TRT - TTT) Response Headers along with Visualization tools in JMeter 10 incomplete Standard analytic reports - CSV containing Target response time, Apigee policies)
awatson@llbean.com, and bbaxter@llbean.com or markie.struble@dynatrace.com do you know how to do this?
Answer by Jan-Hendrik W. ·
Hi Kris,
I see, you are using Apigee. Did you manage to make a dynaTrace agent work on it, so that you can see the communication to other tiers?
Jan
