Answer by John R. ·
We have packaged up the Java agent with the 32 and 64 bit web server agents for Linux into one RPM. After testing it seems to work, but I wanted to confirm if anyone has run into an issues with packaging the three different agent installs into one?
Answer by Chenjie Z. ·
Apart from the permissions, you also need to confirm whether the target server is 32 or 64 bit and point to the corresponding path in agentpath. You may run into trouble if your 32 bit process reads a 64 bit library.
