• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Ed P. · Aug 23, 2014 at 06:16 AM ·
dynatrace Popup not getting focus
6.0.0I have seen the following at two clients now. Every other popup, opens behind the  window that you clicked on. If maximized, you have to kill client. Start client again this time not maximized, click on drill down e.g. measures. Then click on create measures. This screen is hidden under the measures screen.  Drag from behind measures screen and complete. This happened both times on a WebEx. The focus remains on the screen you were busy with and not the new screen.
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Aug 24, 2014 at 12:37 AM
Hi Ed. Maybe this is realted to what is described in the latest Tech Alert around Java 7 Update 65 & 67. Can you check which Java Version the clients used? Technical Alerts dynaTrace DATM
Comment
0 Show 1 · Share
avatar image Ed P. · Aug 26, 2014 at 10:54 AM 0
Share
Both clients are using fat Client only
avatar image
Answer by Ed P. · Aug 26, 2014 at 04:04 AM
One has Java version 7 update 67. and the other says 1.7.0_25.
Comment
0 Show 0 · Share
avatar image
Answer by Andreas G. · Aug 26, 2014 at 07:54 PM
Hi Ed. I forwarded this to the engineering team. They have not seen this behavior nor were they able to repdroduce this with the Java versions you listed. Can you create a support ticket for this including the support archive which will contain the client logs.
Comment
0 Show 0 · Share
avatar image
Answer by Dave M. · Aug 27, 2014 at 12:04 AM
Hi Ed,
During some recent training sessions we observed this type of behavior when using the dynaTrace client and WebEx.  It does not seem to occur when not using WebEx, so it appears to be some strange interaction between WebEx and the Eclipse UI framework.
dave
Comment
0 Show 0 · Share
avatar image
Answer by Chris G. · Oct 31, 2014 at 01:15 AM
I had the same problem with webex. See my post here:
https://community.compuwareapm.com/community/display/INTDTFORUM/Problems+with+Webex+and+dynaTrace+client?focusedCommentId=179732573#comment-179732573
Comment
0 Show 0 · Share
avatar image
Answer by Graeme W. · Nov 05, 2014 at 02:41 AM
I also see this problem regularly with 6.0.0.7000
Next time, I'll collect a support archive ...
-- Graeme
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
3 People are following this question.
avatar image avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
