• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Ramya M. · Sep 05, 2014 at 05:14 AM ·
dynaTrace client 5.6 installation
Comment
People who like this
0 Show 0
â–¼
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Ramya M. · Sep 05, 2014 at 05:18 AM
We are trying to install dynaTrace client 5.6 in our machine which is Windows 7 (64 bit). We couldn't find client with 64 bit version in Compuware site. We tried to install 32 bit version of client in the machine and we are getting the attached error message.
Can anyone help us on this? dynaTrace Client 5.6 install message.docx
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Rob V. · Sep 05, 2014 at 05:34 AM
Hi Ramya,
First thing: there is no 64-bit version of the v5.6 dynaTrace client, just a 32-bit client. It's perfectly OK to run the 32-bit client on Windows 7 (64-bit). FYI: as of v6.0 however there is a 64-bit version.
Second thing: the error message. Every time I've seen that, it's been because the download of the installer MSI got corrupted. Please try downloading again to see if that helps.
Rob
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Ramya M. · Sep 05, 2014 at 06:10 AM
Thanks Rob! The thing is we have downloaded it two times totally; first one was before 4 months and we downloaded it again yesterday. Both installer file throws same error!
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Ramya M. · Sep 05, 2014 at 06:49 AM
We downloaded it again but still facing the same issue! Any solution for this?
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Rob V. · Sep 05, 2014 at 08:29 AM
Hmmm. for me a new download always worked, so I've never had to troubleshoot this further than that. And the error message is not that helpful.
I just downloaded dynatrace-client-5.6.0.5802.msi  and it was 112,077,312 bytes. It installs just fine. What do you have? Do you have local administrative rights on your machine to install software locally. I'm afraid I can't be much more help on this one. Either someone else will have to add their advice or you should talk with support.
Sorry,
Rob
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Andreas G. · Sep 05, 2014 at 08:31 AM
Instead of downloading the client you can also try to use the WEb Start Client. Simply open a browser and open the website of your dynaTrace Server. The dynaTrace Server hosts a management Web Site on default port 8020. So - opening the browser on http://YOURSERVER:8020 should get you to the dT Server Web Site. From there you will find a link to launch the Web Start Client. It will install the client using Java Web Start Technology.
Comment
0 Show 2 · Share
â–¼
avatar image Rob V. · Sep 05, 2014 at 08:34 AM 0
Share
Great point Andi. Though it is still interesting why the installer fails.
avatar image Ramya M. · Sep 06, 2014 at 06:40 AM 0
Share
Thanks Andreas! I have successfully installed the client using Web start client method! It is resolved.
avatar image
Answer by Dave M. · Sep 05, 2014 at 10:55 AM
At the bottom of the downloads page there is an MD5 file that contains a listing of the MD5s for the downloads.  You can use this to verify that the file downloaded correctly.
This is the line for the 5.6 Windows client:
acb23c17045f08e84a104f2b52e3bde3 *dynatrace-client-5.6.0.5802.msi
I would recommend using the Microsoft FCIV tool, if you don't already have some other tool for calculating an MD5.
Here is what I get when I run it on my machine:
c:\tools\fciv\fciv.exe "dynatrace-client-5.6.0.5802.msi"
// File Checksum Integrity Verifier version 2.05.
acb23c17045f08e84a104f2b52e3bde3 dynatrace-client-5.6.0.5802.msi
I just downloaded the 5.6 client, verified the MD5, and it installed fine for me, so I would check your MD5 and then troubleshoot other things like Rob mentioned (and of course the Web Start Client is another option, as Andi already mentioned).
HTH,
dave
Comment
0 Show 0 · Share
â–¼
Welcome to the
Dynatrace Community Forums
Check out the Community User Guide and First steps in the forum to learn how to get started.
Community Member of the Month
December 2019
Announcing Dynatrace's Community Member of the Month for December 2019, Enrico F.! Click here to read more!
Employee Member of the Month
December 2019
Announcing Dynatrace's Employee Member of the Month for December 2019, Silvia M.! Click here to read more!
Live webinar: Ensuring Digital Business Availability with Dynatrace
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 12, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Register here
Follow this Question
Answers Answers and Comments
3 People are following this question.
avatar image avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api errors dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java browser agent community user guide hybris javascript appmon sensors good to know search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow diagnostics user session monitoring unique users continuous delivery configuration alerting NGINX splitting business transaction client 6.3 installation chart database scheduler apache mobileapp RUM php dashlet azure purepath plugins agent 7.1 appmonsaas messagebroker nodejs 6.2 incidents android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
