• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home
  • Public Forums
avatar image
Question by Antoine M. · Sep 18, 2014 at 01:05 AM ·
Pure Path Data
We're having an interesting problem in DynaTrace.  We have the following 3 system profiles setup in our environment.  All of the applications run on the same WebSphere Application Server.
Dev App 1 Profile - contains a group of JVMs/applications that handle its business functions.
Dev App 2 Profile - contains a group of JVMs/applications that handle its business functions.
NOTE: App 1 and App 2's businesses are totally different.
Dev Settlement Profile - contains a group of JVMs/applications which handle the settlement of transactions sent by App 1 and App 2.  The Settlement group of JVMs/applications also contain their own set of business functions.
Example:
App 1 handles a transaction in its boundary and then puts a message on queue and an application in the Setttlement system profile listens to that queue and processes the settlement portion of the transaction.  If everything goes right, an ack is sent back to App 1 to denote a success.
Issue : RFH2 Header enabled and missing pure path in Settlement.
Because of the use of queues and several JVM hops in our business transaction, we've been instructed to append the RFH2 Header on the queue.  This allows DynaTrace to use the same purepath tag ID and stitches together a full round trip of our business transaction.
In App 1 and Settlement's case: App 1 starts a new transaction (pure path TAG ID is constructed in App1) and puts a message on a queue that an app in the Settlement system profile listens to and the Settlement app processes it.  The problem is the pure path data of the Settlement app is being housed in the App 1 profile.
Meaning, we are seeing the pure path data of the Settlement application (processing of App 1 message sent) in App 1 System Profile.  But when we look at the Settlement Profile, there is no pure path data available as if nothing was ever processed.
Ideally, what we would like is to see the pure path data in both the App 1 and Settlement System Profile.  If that is not possible, then we would want to the pure path data housed in the Settlement System Profile since it is a function of one the applications in Settlement.
FYI - If we disable the RFH2 Header, the pure path data is housed in their respective system profiles but that isn't a true reflection of the full end-to-end business transaction.  App 1 starts a new transaction (new pure path TAG ID) and when it puts the message on the queue for the Settlement application, a new pure path ID is created.  Meaning the transaction is not stitched together.
Is this possible in DT?  I hope this is clear.
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Sep 18, 2014 at 09:23 PM
Hi. Cross System Profile PurePaths are not supported by dynaTrace. There are some discussions going on in the forum when searching for that term:
  • Purepaths crossing System Profile
  • PurePath Behavior When Crossing System Profiles
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
