• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Anoh B. · Mar 04, 2015 at 05:22 AM ·
Export dynaTrace sessions data in SQL Server
Is the dynatrace team planning to setup a process whereby the sessions could be exported in a database (i.e., SQL server) so it could be used to create custom reports?  I am creating weekly management reports and they are pretty arduous given the fact that I have to copy and paste the purepaths data in an Excel file and massage them to create the custom reports.  It would be a lot easier if there was a way to export the data directly into SQL and write queries to create the reports.
Anoh Brou
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Klaus E. · Mar 04, 2015 at 06:40 AM
Hi Anoh! Do you have a sample what this report looks like? Dynatrace comes with a couple of export mechanisms the question is which one is the right one for you. Eg. Business transaction export, rest interface,...
Comment
0 Show 3 · Share
avatar image Anoh B. · Mar 05, 2015 at 02:20 AM 0
Share
Hi Klaus,
Here is a sample of a management report that I have been creating.  It is really painful as I have to copy the purepaths data into Excel, massage it and create the report along with the graphs.
AnohOdyssey Prod Summary Report 2014-10-14 2014-11-01.xlsx
avatar image Andreas G. ♦ Anoh B. · Mar 05, 2015 at 02:28 AM 0
Share
Have you looked at the Server- and Clientside XML Reporting? It allows you to pull out data from any dynatrace dashboard and receive it as XML. You can also use the Reporting (REST) to get any type of report format we provide (CSV, Excel, ...). So - using these REST INterfaces allows you to query any type of data from dynatrace in a programatic way. You could write a little tool that queries that data through REST - simliar to what you proposed for getting data from a SQL Database.
I hope this works for you. The REST Interfaces we provide are pretty powerful and many users use them to pull out data in an automated way and use it in external tools or reports
Andi
avatar image Anoh B. Andreas G. ♦ · Mar 05, 2015 at 10:03 AM 0
Share
Thank you Andi!  I will give it a try.
Anoh
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
