• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Masa O. · Mar 18, 2015 at 07:20 AM ·
Server side Reporting Question
I am trying to follow steps shown in this page: Server- and Clientside XML Reporting
Specifically trying to get a xml page back from a REST call.
I have the following dashboard name: [Broken image]
I am trying to get a response via Postman GET and here is what I see:
[Broken image]
Not sure what the red dots represent..has anyone ran into this issue?  Does this documentation work for others?
Thanks in advance.
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Masa O. · Mar 18, 2015 at 07:22 AM
Sorry looks like my images broke. The first one is this
Second one is this:
Comment
0 Show 0 · Share
avatar image
Answer by David M. · Mar 18, 2015 at 08:00 AM
Are you adding an Basic Authorization header to your request?
David
Comment
0 Show 0 · Share
avatar image
Answer by Masa O. · Mar 18, 2015 at 09:09 AM
Hi David,
Yes I've added basic auth with username and password. Is there anything else to add there?
Masa
Comment
0 Show 0 · Share
avatar image
Answer by David M. · Mar 18, 2015 at 11:47 PM
Hi Masa,
Okay, just making sure about the username/password.
Can you try sending the request with these parameters
<DTSERVER>:port/rest/management/dashboard/<DASHBOARD NAME>?type=XML&format=XML+Export.
If that does not work, can you try this REST service
<DTSERVER>:port/rest/management/reports/create/<DASHBOARD NAME>?type=XML&format=XML+Export
Also, for the name of your dashboard in the URI, are you putting it as RestTest2.dashboard.xml, it should just be RestTest2.
David
Comment
0 Show 0 · Share
avatar image
Answer by Masa O. · Mar 19, 2015 at 02:43 AM
Hi David,
Thanks you for your reply David, but I am still facing the same issue.
This is the same output for both options you've provided me.  Is it possible that my dt server needs some configuration changes?
Comment
0 Show 1 · Share
avatar image David M. · Mar 19, 2015 at 02:57 AM 0
Share
Hi Masa,
Okay, can you check in your server setting to make sure that the Web Services are enabled.
Also, can you check you can get what you are wanting to by browsing to the the dtserver:port and going through the options to get to the XML dashboard. For 6.1 the Links are Automate & Manage dynaTrace -> RESTful HTML Services -> Dashboard -> Select Details under the dashboard you would like -> Change Report Type to XML and create report.
David
avatar image
Answer by Masa O. · Mar 19, 2015 at 04:11 AM
aha! It worked David! Thank you so much! (big grin)
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
2 People are following this question.
avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
