Hi All,
We want to monitor some process which is running on a particular server as the number of processes are huge so we prepare script which giving me list of process which are down using generic execution monitor.
Now I want to represent this in dashboard but I am unable to do that kindly anybody suggest me how do display this information on dashboard.
Please Suggest.
Best Regards,
Jaydatt.
Answer by Jaydatt D. ·
Hi all,
Any suggestions????
Hi
the generic executor monitor plugin basically executes your remote command and will then return a success measure on whether output of that executed command matches your regular expression. You can then chart this success status.
Andi
Hi Andi,
In our case we code 1 batch file and using generic executor monitor plugin we run this batch file and in detail message of generic executor monitor plugin we get result. Can I show this result in dashboard.
Please find the attachment for further detail.
Jaydatt
Hi Jaydatt,
A monitoring plugin can only return measures to the dynaTrace collector/server. Those measures need to be numeric so we can create a time series and chart the measure over time. In your case that would mean instead of the generic execution plugin build a custom one that returns multiple measures, one for each of the apps you monitor. That measure could then have a numeric value, e.g. how many instances of that app are currently running. That way you can not only show a snapshot of the values but have a history over time and use this for alerting, defining incidents based of upper/lower thresholds.
Right now with v4.1 you have to define the list of measures your plugin returns static, with the next release v4.2 we also support dynamic measures.
Best, Roman
