• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by David F. · Nov 16, 2013 at 04:28 AM · continuous delivery
Treating Multiple Requests as a Single Transaction with LR
We have a front-end that cannot be instrumented connecting to a back-end that is instrumented. A single 'user action' can generate many requests to the back-end, but dT treats every request that is part of that transaction exactly the same. When dT aggregates information about a LR transaction, it treats EVERY request equally. So I could have one backend request that takes 100ms, and another that takes 900ms, and the average for that tagged transaction is 500ms.
I thought that setting the ID in the Request Header would resolve this issue (see Grouping Multiple Tagged Requests Together) but it seems that the ID isn't used for anything other than linking specific transactions between tools.
Am I correct in assuming that setting the ID won't help me, or does DT actually use it to determine what a single transaction really is?
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Andreas G. · Nov 16, 2013 at 05:46 PM
Hi
The ID field by default will only show up in the details of the purepath. But - what you can do is create a Business Transaction that splits by the ID Field. Simply create a Business Transaction and use the Tagged Web Request Measures as split measure. This measure allows you to specify which value of the incoming tag (ID, NA, PC, ...) it should return which is then used for the split
Andi
Comment
0 Show 0 · Share
avatar image
Answer by David F. · Sep 25, 2014 at 05:21 AM
Thanks andreas.grabner@grabnerandi.at. We did this working with our support guy. It isn't quite what we were asking for, since DT doesn't really treat that set of related PurePaths as a unique entity; and is limited to the max # of splits of a business transaction.
It does, however, provide a way to view the top x slow unique transactions, which is very helpful.
Comment
0 Show 0 · Share
avatar image
Answer by David F. · Sep 25, 2014 at 05:24 AM
Looking at our conversation on RFE - Generic Performance API, there is the possibility that we can use the UEM API to create Page Actions that correspond directly to 'user action', and then correlate the individual requests to that Page Action.
I will continue to investigate the UEM API that is exposed and see if it can help us out.
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
1 Person is following this question.
avatar image
Related Questions
PHP and Test Automation
Automation Client in an Intrumented app - how to get the app measures as test checkpoints?
DynaTrace 6.3 and Jenkins 1.625.3 connectivity issue
Manage Remote Batch Processes through Eclipse Plugin
Integration with TruClient
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
