Resolved! How to disable redundant modules on ActiveGate 69 Views 2 replies 0 kudos activegate dynatrace saas
ActiveGate directory disappeared, but it is still running 71 Views 2 replies 1 kudos activegate extensions
Resolved! Classic dashboards - service health with dynamic filter tag 131 Views 5 replies 0 kudos dashboards classic
DSFM Metric 'Active Gate - Communication - Messages - Dropped' 50 Views 1 replies 0 kudos activegate dynatrace saas metrics
deep monitoring of process java disabled by rule 57 39 Views 1 replies 0 kudos deep monitoring processes services
Resolved! Tagging Kubernetes Clusters, Workloads, and Pods 11436 Views 31 replies 4 kudos kubernetes tagging
Api detection rules for using in memory profiling use cases 27 Views 0 replies 0 kudos alerting memory service analysis
How to use ActiveGate as a beacon forwarder in SaaS deployment 36 Views 0 replies 0 kudos activegate dynatrace saas real user monitoring
REST API -OAuth Authentication Failed with status code 400 136 Views 0 replies 0 kudos Bad Request in REST API Request Bearer Token from the Dynatrace SSO system
Configure IBM MQ extension in OneAgent instead of ActiveGate 183 Views 1 replies 0 kudos extensions ibm mq
SSL Certificate Monitor extension - monitor and alert only necessary Certs 232 Views 1 replies 0 kudos extensions ssl
Ideal or recommended way of monitoring processes in container 324 Views 9 replies 1 kudos container docker oneagent
App Metric injest - Request failed: {"code":403,"message":"Missing required permission."} 74 Views 0 replies 0 kudos custom app data ingest
