Hi Team,
I want to filter out only those business transaction that having failed % greater than 0.
Please find below snapshot.
Only Error specified above.
When there is transaction with error only that transactions should get in that BTM.
Please suggest.
Jalpesh Shelar
Answer by Andreas G. ·
You can create a Business Transaction that uses the Functional Health Measures for these Error Rules as Filter Measures. so - you would create a BT that filters on those PurePaths where JavaScript Syntax Error > 0 OR Database Exceptions > 0 OR ...
Every Error Rule that you create is automatically available as measure. Therefore you can use these measures as Filters in your BT
Andi
