We are in a process of rolling out our new website which is all based on AngularJS frontend. All the Key functionality is based on Service based model running on different application. I have a requirement to capture response times and total count of the method calls and i cannot create a Measure / BTs for such URI request because URIs are dynamic in nature. For example ...
/xxxx /600668/categories
/xxxx/600668/categories/schedule
/xxxx/600668/products
If you notice in above URIs i have numeric value 600668 which will be changed dynamic depends on location from which the call is made so i cannot create Web Request Measure for such URIs.
What is the best way to handle this situation where URIs are dynamic
Answer by Dave M. ·
You can define measures that match just the relevant part of the URLs to define your BTs,
Example from a product page that is dynamic: Product.png
HTH,
dave
Answer by Prashanth K. ·
All of the Website starts with XXXXX (Foundation-api) and under it there are multiple application .. for example ..
Menu-Services:
/foundation-api/600668/categories |
/foundation-api/600668/categories/schedule |
/foundation-api/600668/products |
/foundation-api/product/scheduleandavailability/600668 |
/foundation-api/600668/products/combo |
/foundation-api/600668/stockout |
/foundation-api/messages/600668 |
/foundation-api/upsell/600668 |
Login:
/foundation-api/auth |
/foundation-api/token |
/foundation-api/users/4525324 |
/foundation-api/orders/customer/4525324 |
/foundation-api/users/4525324/favorites/cafes |
/foundation-api/users/4525324/favorites |
/foundation-api/users/4525324/phones |
/foundation-api/users/4525324/preferences/email |
/foundation-api/cafe/600668/hours/0 |
/foundation-api/rewards/4525324/503201227041 |
Answer by Vinh L. ·
So is the numeric # (600668) assigned to a fixed location? Do you get a different # the next time you access the same location?
Have you tried changing the BT splitting option to no restriction or take the default restrict to 5000? Try this option and see what you get.
Business Transactions missing when splitting criteria is null/empty.
How to feed External data into Dynatrace to be used into Business Transaction Filtering condition
Is it possible to define incident rules only for certain BT splittings?
Capture Specific Value in the splittings column
Can't filter a Business Transaction on a Web Requests full URL
