question
Anthony P. avatar image
Anthony P. asked ·
IBM WebSphere eXtreme Scale (WXS) Transaction Call Monitoring
Recently a client wanted to monitor their large scale IBM WebSphere Commerce Server and eXtreme Scale application with dynaTrace.  The application has a web server based front end which directs requests to a large number of application servers running WCS and WXS.  With the dynaTrace Java Agent, we were able to monitor both the WCS and WXS JVMs.  However, out of the box (with dynaTrace 4.2.0 at least) we were not able to completely follow transactions from WCS Agents to WXS Agents.  Here is a document that outlines the configuration we used to monitor these WXS transaction calls along with the custom Sensor Pack.
dynaTrace IBM_WXS_RMI Documentation.pdf
com.dynatrace.custom.tpc.RMI.IBM_WXS_RMI.dtcs
Please note that this was analyzed, designed, and developed for this particular client environment - use the documentation as a reference and the Sensor Pack at your own risk
production
Larry F. avatar image
Larry F. answered ·
I am interested in this post. The link to the PDF doc no longer works. How can I get the PDF doc ?
Share
Matt M. avatar image
Matt M. answered ·
I added the methods needed to capture message timing for clients using the XIO protocol. comdynatracecustomtpcrmiibm-wxs-rmi.zip
Share
Nate A. avatar image
Nate A. answered ·
Nice one TPC. There may be another local Minnie customer that will use this shortly.
Share
Lopes D. avatar image
Lopes D. answered ·
Thanks for sharing, very clean and well made document! Should be helpful in future WXS implementations
Share
Haeun C. avatar image
Haeun C. answered ·
This is brilliant, thank you! (smile)
Share
