Hi all,
I was asked recently to compare uptime of an application to a few others in our Dynatrace Application Monitoring system. He is looking for things like a % that the application was available. Any help to report this would be great
Best,
Kyle
Answer by Saanjeith V. ·
If this is a browser-facing app, you could create a URL Monitor which hits the application every x minutes. This wouldn't necessarily be the most accurate way to obtain an availability metric(The higher the interval, the worse your resolution) but would be a quick and easy way to do this.
Cheers,
-Sanj
Thanks Saanj, I tried to set up a URL monitor but I am consistantly getting connection refused. Other URL monitors are not failing for this particular collector, where could I look to fix this?
Have all Tests resulted in a failure? I would check to see if you are utilizing the correct protocol (HTTP/HTTPS) and/or make sure that application does not have firewall rules for incoming connections?
