i am using the URL MONITOR to monitor a certain URL in a Website that is distributed on multiple servers.
My issue is (example):
Host: server1
SITE: myWebsite
URL: /firstpath/google.htm
Match Content: MAP
I also select the host that is pre-configured in dynatrace in
So, whenever i run my monitor i have the following error:
Detailed message: URL: http://server1:80/ /firstpath/google.htm Expected string "MAP" didn´t match |
Even using this URL inside the server it does not open this webpage.
So i think the problem is here, because dyna can reach the server with success.
My question is:
How can i make this work?
