• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Allan S. · Sep 17, 2015 at 09:57 PM ·
How does "equals", "contains", "matches", etc, work behind the scenes.
Due to concerns about possible DT server performance impact of setting up measures that use these built in conditions, how do these conditions work behind the scenes? Is it a regex, or something else? If regex, can we see the regex's being used?
Thanks. @Cesar Quintana @Cesar Quintana
Comment
Rajesh S.
Florent D.
Saanjeith V.
People who like this
3 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Best Answer
Answer by Markus B. · Sep 18, 2015 at 01:44 PM
These string matching operators (equals, starts, etc.) are not implemented with regexes but with efficient string matching functions. I recommend to use simple string matching operators instead of regex whenever possible as that will perform better. Regex evaluation can be quite expensive in terms of server CPU usage. Starting with 6.2, the server log will contain statistics about the most expensive regular expressions and the strings they are matched against.
Comment
Ben S.
Allan S.
Saanjeith V.
3 Show 1 · Share
avatar image Allan S. · Sep 18, 2015 at 03:54 PM 0
Share
Perfect. Thank you!
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
8 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
