question
Lakshmi P. avatar image
Lakshmi P. asked ·
How to create a BT to capture purepath response time split by method name, class name?
Hi
I created a BT to calculate pure path response time t split by method name to identify the slow transactions and correlate the pure path with method name, so that there is no need to drill down to identify the method.
But now my customer requesting the class name of the all the methods of slow transactions. It is really difficult to go to methods, search with method name and identify its class name. So I edited my BT to add another split by class name expecting to analyse the BT and split by (method name, class name). But after the edit, it is not showing any trasactions/calculations. I think because of the split class name, it is unable to calculate the results.
Below is my BT with Class name Split
Below is my BT with out Class name Split
Could some one help me to create BT to meet my requirement.
6.1
1 Answer
Nicolas V. avatar image
Nicolas V. answered ·
Hi
The measures Class/Method Name Value represent the number of calls of method with a specific classname/methodname value within a PurePath. Those measures return a numeric value, which can be used in filters or results, but not as a splitting.
I would suggest the following:
- remove the split results measures
- check the BT returns what you are expecting with that configuration
- open a method/method hotspots dashlet with the class column
- add the BT as a filter for that dashlet
That should answer your question.
Nic
1 comment Share
Actually it is possible to use the class/method name and use that for splitting options...
0 Likes 0 · ·
