question
Paul M. avatar image
Paul M. asked ·
how to change the webui context path for reverse proxy
How can the jetty context path be changed for the webui so that it is accessible via http://localDomain:9911/dynatrace/ rather than just http://localDomain:9911/. This is required for most reverse proxy configurations since UEM doesn't use relative links.
6.3NGINX
Peter Z. avatar image
Peter Z. answered ·
Hi Paul,
Sorry for the delay. This is not possible right now. Most of our URLs (e.g. a dashboard share URL) wouldn't work out of the box like they are implemented now. It would take quite some effort to accomplish the config for this. I've put in on my list.
Please also find the list of upcoming improvements at
https://answers.dynatrace.com/idea/132999/planned-...
Share
John R. avatar image
John R. answered ·
I don't see anything about the ability to change the context root in the improvements list above. Have there been any changes to make this possible for the 9911 address (http://localDomain:9911/) or for the 8021 address (http://localDomain:8021/)?
Share
