question
Jose C. avatar image
Jose C. asked ·
Java RESTful access returns 403
I am currently trying to access the RESTful interfaces using Java, but I keep receiving a 403 HTTP response code. I am assuming this has to do with the HTTP Basic authentication. Below is my code:
HttpURLConnection connection = (HttpURLConnection)url.openConnection();
connection.addRequestProperty("Authorization",  "Basic " + authStringEnc);
int responseCode = ((HttpURLConnection) connection).getResponseCode();
logInfo("The response code is" + Integer.toString(responseCode));
The user that I am using is admin, thus having all privileges to carry out web services calls to the dashboards. Any suggestions?
appmon6.3rest
supriya k. avatar image
supriya k. answered ·
any one please answer this.....i am stuck with same
Share
Ahmed E. avatar image
Ahmed E. answered ·
Hi Jose -- Where did you set up the admin user credentials?
Share
