question
keerthi C. avatar image
keerthi C. asked ·
Dynatrace server load balancing?
We have installed dynatrace server,collector and agent in a cloud server and we are trying to monitor multiple hybris nodes with collector load balancing provided in dynatrace.But if the cloud server itself is down where we installed the dynatrace then how we will do the monitoring?Is there an option to do a load balancing?Do you have any architectural diagram for this?
configurationagent6.3collectorclientapachehybris
1 comment
Hi @keerthi Chakrath,
you'll find helpful info here:
https://answers.dynatrace.com/questions/148609/dyn...
Ciao, Raff
0 Likes 0 · ·
1 Answer
Rob V. avatar image
Rob V. answered ·
Share
