I've ticked the 'requires ssl connection' but the connect times out. I've added the SQL server's certificate to server/conf/jssecacerts & restarted the server, but still no luck. There is nothing in the docs about using that switch either!
Answer by Andreas G. ·
Hi there. Did you manage to connect via SSL? If not I suggest opening a support ticket so that our colleagues can look into that
