We have a system profile having huge number of BTs and Measures. Now we want to know the measure which are not in used, so that we can delete the same which will improve DT performance. Is there any way we can identify it?
Answer by Brett B. ·
Hey Harsh,
I see David's comment but I read your question as "which aren't being used by users, in dashboards or in BTs" as opposed to "which have data".
To see which aren't used in BTs, I'd export the System Profile into xml. Then search that xml for any measure you'd like to remove - if it shows up in a BT description, you know it's being used there. Technically, you could try to delete the measure. When you click delete, a dialog box will tell you if that measure is being used by a BT.
To see which aren't used in dashboards, you'd have to download all of your dashboards and execute the same process as for BTs. (If you want to export all dashboards at once, the easiest way to do so is by making a support archive which only includes dashboards).
Both of these may be laborious tasks.
HTH
Hey Brett,
Thanks for your response. Suggested method is manual work and we have more than 500 measures in 1 profile. We need to do this for 3 profiles which would be tedious work.
So is there any other workaround?
Harsh
