Hi guys,
I am charting the Database Execution Count as a measure and when I toggle between Sum and Count under Aggregation I am seeing different values. The Sum values are much higher than the count values. I think the "Count" aggregate tells us how many PurePaths were calculated for this measure and "Sum" tells us the how many database executions were made in a given time frame. Is this correct or I am wrong?
Stan
Just curious, is this screenshot part of Dynatrance installed on-premise or on AWS? I was using AWS subscription, so would like to try out if this service/view is possible in AWS.
Answer by Rob V. · Oct 06, 2016 at 01:30 PM
Hi Stan,
Yes, "count" is showing you how many samples were processed in that time interval. The "sum" is, as you figured, summing up the total of the results of each sample. So if you had three of these in a 10-second interval with "execution counts" of 10, 20, and 30, the count for that interval would be 3 and the sum would be 60.
Rob
Answer by Taneshaa t. · Oct 06, 2016 at 01:35 PM
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
Configuration for JUnit Test Perfomance View (Business Transaction, Measure, Sensor pack methods) 2 Answers
Glassfish JMX measure Database pool usage & Current thread count 2 Answers
Why would an Oracle database get recognized as a generic database in the Work Flow 3 Answers
Performance Warehouse data loss 2 Answers
