• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
  • Home /
  • Public Forums /
  • Application Monitoring & UEM /
  • AppMon & UEM Open Q&A /
avatar image
Question by Annmarie T. · Oct 12, 2016 at 04:51 PM · appmon alerting database server production
Daily Alert from Performance Warehouse: Exception: ERROR: canceling statement due to user request
I am getting an alert from my Performance Warehouse daily with the following exception:
Has anyone ever run into this? I cannot seem to find it on the forums or in the documentation. Any clue how to fix this?
Annmarie
Comment
People who like this
0 Show 0
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Joe H. · Oct 12, 2016 at 05:53 PM
Annmarie,
It's possible this is being caused by running backups on the PW database against tables that don't need to be backed up. Here's some suggestions:
  • Do not backup the tables measurement_temp1 and measurement_temp2 - these tables only contains data from max 30 min. These are the tables being used to write the data from DT server to the DB, after 30 min, the data is moved to the measurement_high table
  • Try to reduce the priority or resource level of the backup (if possible), so that the normal DB operations to not have such a big delay
If this does not resolve your issue I suggest you open a support case and be sure to include a support archive. There is likely additional messages in the server.0.0.log file indicating further useful information.
Joe Hoffman
Comment
0 Show 0 · Share
How to get started
First steps in the forum
Read Community User Guide
Best practices of using forum
NAM 2019 SP5 is available
Learn more
LIVE WEBINAR
Register here
Follow this Question
Answers Answers and Comments
20 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Performance Warehouse migration - SQL Server
Could not convert socket to TLS [EmailSender] WARNING
Application Process Unavailable only for several processes
need to configure one alert,if server is down.please tell me how to configure the alert.
How to change the Xmx setting of the dtserver?
Forum Tags
dotnet mobile monitoring load iis 6.5 kubernetes mainframe rest api dashboard framework 7.0 appmon 7 health monitoring adk log monitoring services auto-detection uem webserver test automation license web performance monitoring ios nam probe collector migration mq web services knowledge sharing reports window java hybris javascript appmon sensors good to know extensions search 6.3+ server documentation easytravel web dashboard kibana system profile purelytics docker splunk 6.1 process groups account 7.2 rest dynatrace saas spa guardian appmon administration production user actions postgresql upgrade oneagent measures security Dynatrace Managed transactionflow technologies diagnostics user session monitoring unique users continuous delivery sharing configuration alerting NGINX splitting business transaction client 6.3 installation database scheduler apache mobileapp RUM php dashlet azure purepath agent 7.1 appmonsaas messagebroker nodejs 6.2 android sensor performance warehouse
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
