question
benjamin j. avatar image
benjamin j. asked ·
WSMB Agent - Instrument only specific execution groups
We have a number of execution groups in all of our WSMB brokers that do not need to be monitored. We don't want the agent to be installed into those groups, as it will consume a license that we would require for the other groups.
In this page, there is a comment which describes how it could be done in 6.3.
Is this also applicable to 6.5?
Will it stop the agent from being injected into all groups under a broker?
https://community.dynatrace.com/community/display/DOCDT63/WebSphere+Message+Broker
"In case you want to implement Dynatrace agent on just the execution group and not the broker here is the syntax below. Please follow the steps above and only do this if you want to instrument the execution group only.
set broker active on a certain execution group by using _mqsichangeflowuserexits:_
mqsichangebroker <broker> [-x <path to libdtagent.lel>]
mqsichangeflowuserexits <broker> -e <ExecutionGroup> -a dtwsmbagent"
agent6.3+messagebroker
Babar Q. avatar image
Babar Q. answered ·
Hello Ram,
Postscript: set broker active on a certain execution group by using _mqsichangeflowuserexits:_
https://community.dynatrace.com/community/display/...
Babar
Share
Ram P. avatar image
Ram P. answered ·
Is there some way we can enable only for specific execution groups.
Ram
Share
Nathan M. avatar image
Nathan M. answered ·
Hi Ben, I Once installed broker agents in dynatrace 6.2 and had a concern just like the one you raised here. If i remember correctly there is no way to custom pick which execution group is and is not instrumented with an agent. The work around here is to configure your system profile in such a way ( agent group naming rules) so that only execution groups you want are included in the system profile. All execution groups will show up in the agent overview, but agents not mapped to a system profile will not consume a license. Hope this helps. Thanks.
Share
