question
Drew C. avatar image
Drew C. asked ·
Configuring custom pass/fail thresholds in Test Automation dashlet?
Hello, I want to set a PurePath Response Time threshold of 100 ms -- if an API exceeds this time, the test will be marked as "Failed". Is this possible to achieve using the Test Automation settings shown below?
If so, what should the settings be changed to for this specific use case?
Thanks!
configurationdashboard6.3web performance monitoringtest automation
1 Answer
Andreas G. avatar image
Andreas G. answered ·
Hi Drew
This is currently not possible. The current mechanism is based on our automatic baselining and alert in case your response time is outside the baseline.
We are however working on a REST API where you can either set the Failure status of Tests from "the outside". We also think about allowing you to set thresholds for individual measures per test - but thats for future versions
Andi
1 comment Share
Hi @Andreas G.,
Thanks for you reply, looking forward to future versions where this kind of configuration is possible.
Best,
Drew
0 Likes 0 · ·
